KMG 000 First Build
Re: KMG 000 First Build
Post by John Parchem » Wed Feb 25, 2015 10:31 pm
That rosette will look good.
Post by ken cierp » Wed Feb 25, 2015 11:23 pm
Please ask if you are not sure about something you know the old adage measure twice cut once -- thank you
The Abalone gets two strips of BWB on the inside and two strips BWB on the out side. The black lines are slightly thinner on one edge, if placed properly the lines will be/look symmetrical.
John J
Post by John J » Fri Feb 27, 2015 11:52 pm
Glued the rosette last night. Thanks Ken for straighting me out on the order the rosette went together. Started on the top bracing. Glued the bridge plate and the first leg of the x brace.
Nice tight x.
Nice tight x.
Bridge plate.
Bridge plate.
Gluing up the first leg of the x.
JJ
John J
Post by John J » Sat Feb 28, 2015 10:58 pm
Moving along.
JJ
Post by Dave Bagwill » Sat Feb 28, 2015 11:00 pm
And lookin' good :-)
John J
Post by John J » Sun Mar 01, 2015 2:59 pm
Using scraps cut from a flexible cutting board I confiscated proved and excellent barrier from my own ineptitude with a chisel.
Cutting board scraps
JJ
John J
Post by John J » Sun Mar 01, 2015 11:31 pm
Top bracing finished.
JJ
