OOPPPPS!!
Re: OOPPPPS!!
Post by ken cierp » Sat Feb 21, 2015 12:18 pm
I assume you are planning to pre-bend the patch -- are you going to run the grain vertical or perpendicular?
Not sure why hiding the repair at this point is a real big concern -- you know the defect is there no matter what and if it a commission I personally would start over. The carbon fiber or fiber glass cloth would be a much more durable, predictable repair -- long term, its simply a better choice.
tim crain 54
Re: OOPPPPS!!
Post by tim crain 54 » Sat Feb 21, 2015 2:12 pm
after much deliberation I decided to remove the back, this way I will have complete access no matter which repair direction I decide on. Now I'll know how to pull the back off a guitar if I need to again in the future. I was really pleased with my construction, the glue joints were really well fitted. That baby is built like a battle ship. I am leaning towards removing some of the side braces, bending and fitting a piece then laminating it to the sides. With the back off, I think that I can do a very clean job of it and be able to clamp the lamination securely with the body supported in the mold frame. The silver lining in this is that I think it highly unlikely that I will EVER make this mistake again!! After taking it apart, it certainly raised my level of confidence in the construction. I'll post my progress.
Re: OOPPPPS!!
Post by John Parchem » Sat Feb 21, 2015 2:25 pm
Now it will be easier to fix, also looks like the back came off clean.
Re: OOPPPPS!!
Post by ken cierp » Sat Feb 21, 2015 3:16 pm
Well there you go --- good thinking!!
tim crain 54
Re: OOPPPPS!!
Post by tim crain 54 » Sat Feb 21, 2015 4:36 pm
Yeah the back came off really clean, just a small chip on the heal block so it should go back together pretty easily. This will certainly make the repair much easier and less noticeable when complete.
Re: OOPPPPS!!
Post by Herman » Sun Feb 22, 2015 4:36 am
Yes Tim, that is courage! Who's the boss? Just take that back off! Well done.
Kent H
Re: OOPPPPS!!
Post by Kent H » Sun Feb 22, 2015 2:55 pm
Nice Job!
I started working on guitars by rebuilding older Kays and Harmonys through pulling the backs and re-bracing utilizing the X style.
Hope I never have to do it with one of my "real builds" since I've progressed.
Knowing how to to pull a back still comes in handy. I'm renovating this old Kay/Oahu square neck and will move on to a Harwood as well.
Thankfully, binding hides the errors!
2014-09-13 14.50.05.jpg (95.37 KiB) Viewed 816 times
2014-08-12 19.04.53.jpg (99.1 KiB) Viewed 816 times
