One pic = 1K words
Re: One pic = 1K words
Post by ken cierp » Tue Aug 12, 2014 2:10 pm
Why so big? 1/8" depth would be just as effective. Those splice tenons add zero strength to the joint, maybe compromise the neck block? They are merely locators, which leads right to -- have two bolts (takes care of the perpendicular) and also adds real strength, countering the lever action of the neck string tension. Oh wait! That's been done before.
Post by Dave Bagwill » Tue Aug 12, 2014 2:59 pm
The splice tenons are glued into the heel with HOT HIDE GLUE , boys and girls, so there is nothing to worry about.
Just kidding :-)
Post by Dave Bagwill » Tue Aug 12, 2014 3:19 pm
More importantly, I did find a pic of the early Taylor butt-joint system. Man it is simple, and worked great. Got the pic from:
http://www.frets.com/FretsPages/Luthier ... reset.html
Post by ken cierp » Tue Aug 12, 2014 4:10 pm
My experimental "lab guitar" constructed 1980 ish, has that style joint retrofitted from a dovetail, still going strong for 8 or 10 years now. On that one the FB extension is glued to the top cut off at the 14th the fourteenth fret covers the seam at the slot. Also I have a 1/2" dowel running all the way thru the heel. You can see it in the pixs
Post by Dave Bagwill » Tue Aug 12, 2014 6:52 pm
Ok. A hardwood dowel to hold the inserts better?
Post by ken cierp » Tue Aug 12, 2014 7:41 pm
Correct
Post by Dave Bagwill » Wed Aug 13, 2014 9:59 pm
What in general would be the recommended minimum thickness of the heel on a butt-joint? Here is a picture of a sweet heel from a gypsy guitar, but of course they are traditionally dovetail joints.
For a butt joint, the heel looks a little thin? Is there a good minimum thickness?
