Warped fingerboard
Re: Warped fingerboard
Post by ken cierp » Sat Jun 28, 2014 3:11 pm
Actually I do have a taper fixture to run through one of our drum sanders so I could taper the bottom before or after the slots are cut. But yes you'll have to make sure there is enough depth in the slots so the frets seat all the way down.
Post by John Link » Sat Jun 28, 2014 11:45 pm
For what it is worth, I glue the fretboard to the neck first, do very fine adjustments as part of attaching the neck and fingerboard to the body, then do more fine adjustments after attachment (like leave more relief under the bass strings than the treble) which assume a flat fingerboard top as the starting point. Then install frets. Never had a problem with pressure from the fret tangs messing anything up but I understand how this could be a worry.
Renee Labordus
Post by Renee Labordus » Sun Jun 29, 2014 9:47 pm
Thank you gentlemen for the very helpful insights.
