I had an idea
Re: I had an idea
Ahhh...if you cant get the scribe into the space, you do have a problem! Good luck!
Re: I had an idea
Maybe try printing on basic Avery mailing labels? That way, just print it and stick it on? Not sure it needs to be clear? I think any distortion by the printer/copier is going to be negligible, and adjustment will be easy enough if you have to widen the pocket.
- Stevie Ray Vaughan
Re: I had an idea
That will work well enough if I know exactly where to place it. I think that clear will allow for better placement.Ken Hundley wrote:Maybe try printing on basic Avery mailing labels? That way, just print it and stick it on? Not sure it needs to be clear? I think any distortion by the printer/copier is going to be negligible, and adjustment will be easy enough if you have to widen the pocket.
Of course I could also mostly cut the pattern out which will allow accurate placement too.
Eric
Re: I had an idea
I did a little experimenting.
Copying, flipping, printing didn't work. The printing always shrunk the image.
Removing the inlay from the back, copying the back, and printing directly to the label created an image of what appears to be the correct size. I'll try testing it by using it for the inlay pattern this weekend.
Eric
Eric
Re: I had an idea
Any updates? If you have not done this yet, please take some pics for us!
Re: I had an idea
Tony:
I'll post an update this weekend. I think that it will work.
The white MOP didn't copy too well, but I can see the outline, which is what I really needed.
Eric
Eric
