Two Cherries curved chisel
Re: Two Cherries curved chisel
Post by Herman » Tue Nov 12, 2013 2:40 pm
Normally I use a chisel upside down for taking down the bracing. After reading this I was tempted to buy me also one of these. But there are a few 50 years old chisels around that I do not use. So why not bending them into an S-form. This is the first result. Looking at the Cherries maybe I might have to curve the top a bit more.
It is low-budget and easy to do.
Lonnie B
Post by Lonnie B » Tue Nov 12, 2013 2:56 pm
Well Herman I'm sure you will succeed in getting the chisel you want. I never would have thought of Be ding one however. Good for you
Post by Dave Bagwill » Tue Nov 12, 2013 4:03 pm
Does it work well, Herman? That's a good idea, I think..
Post by Herman » Tue Nov 12, 2013 4:09 pm
Don't know Dave. I did bend it this afternoon in breaktime. But do not worry, I'll make it work. In some weeks the tenor top will be guinea pig. I'll let you know.
Post by Herman » Wed Nov 13, 2013 3:07 pm
Today I curved the top of the chisel a bit more. And Yes Dave, It really works fine.
Post by Dave Bagwill » Wed Nov 13, 2013 3:30 pm
Nice. I will follow suit. I will call mine 'one Herman' chisels :-)
Post by Herman » Wed Nov 13, 2013 4:01 pm
I prefer you name a guitar "one Herman" and to be remembered that way, instead of becoming the Uri Geller (you know him?) in guitarbuildingland.
This is IMO the proper way of bending a chisel:
-Heat it red hot with an acetylene/oxygen burner. The metal is then like gum.
-Form it the way you want.
-Cool instandly the hot metal in an oil bath. That hardens the stuff.
-Reheat it with a butaneburner or 15 minutes in an oven at 200 degree Celsius.
That takes down the tension in metal and makes it less brittle.
-Polish it : é voilá.
