Okay, I can do the chisel....One more clarification; Regarding using the smallken cierp wrote:6th photo down
http://kennethmichaelguitars.com/neckfitpart1.html
You should use a very sharp chisel -- I have used a Dremel with a 1/4" bit but suggest a lot of practice first. You wan to end up with about 3/32" that actually touches the body
block with 150grit sandpaper to sand the top flush to the neck fingerboard
surface. Does the sanding area include the portion where the tenon inserts
into the body? I know that sanding the fingerboard is a no no but I wasn't
sure about that small area.
Thank you!
