Dishing the cheeks
Re: Dishing the cheeks
Post by John Parchem » Tue Mar 12, 2013 3:56 pm
deadedith wrote:Do you chiselers also clean up with sandpaper, or are you able to get smooth cheeks in that stubborn endgrain just with your chisels?
From the picture I thought it was showing cutting the relief between the cheeks and the tenon. I can not see how one could get a smooth cut on the cheeks from the photo.
On the cheeks I use chisels and scrappers. I for the life of me can not get a flat surface with a sanding block I always end up with a nice curve. At the very end I do you a strip of sandpaper to floss the cheeks against the body.
Post by Tim Benware » Tue Mar 12, 2013 4:21 pm
Dave are you talking about the relief cut so you just have that 1/8" or so edge or the cheeks themselves when fitting the neck angle if needed?
Post by Dave Bagwill » Tue Mar 12, 2013 5:08 pm
Yes, just talking about the relief cut that leaves the outside 1/8" or so cheeks for flossing if needed.
Post by TonyinNYC » Tue Mar 12, 2013 5:36 pm
What is there to clean up? The part that will be hidden against the box? I use a quarter inch chisel and cutting the end grain is not a problem. It cuts cleanly. The eighth that you are not touching, well...since you have not touched it, it needs no cleaning up. Every neck needs some sanding to get a perfect joint against the box, don't they?
Post by Dave Bagwill » Tue Mar 12, 2013 5:40 pm
Yes the side that will be hidden against the box. Perhaps this is just not a problem that is common - probably just what I call laughingly my 'technique'. Anyway thanks for the answers.
Post by TonyinNYC » Tue Mar 12, 2013 5:46 pm
deadedith wrote:Yes the side that will be hidden against the box. Perhaps this is just not a problem that is common - probably just what I call laughingly my 'technique'. Anyway thanks for the answers.
Well how bad does it look that you have considered sanding it?
If your technique is an issue, I certainly am no expert in chiseling, but I take very thin shavings, and taper the cut, going deeper at the tenon. My chisel is a Home Depot purchased .25" buck brothers or some such. It was not expensive, I can tell you that. I use scary sharp to sharpen it, but I think the most important thing is that it is .25" wide, and I take shallow, tiny bites. The dremel works fine, but I feel more in control with the chisel.
Post by Dave Bagwill » Tue Mar 12, 2013 6:33 pm
It's not a big problem, not perfect though.
