harp ukulele project - Gluing down the bridge...
Re: harp ukulele project - I am back but need to refinish.
Sorry, I went away to the mountains for a month no internet, not even cell. My wife and I dropped our youngest off at college and instead of going home to an empty nest ...
But I digress, I came home and I am not happy with my application of EM7000 it is very blue. Maybe my coats were too thick I am not sure. I also had adhesion problems when I tried to buff out before the trip. (See the first picture). Right before the trip I sanded down the damaged are and resprayed. You can see in the pictures.
Here is what the instrument looks like in sunlight. It looks ok in warm light. I will sand it down and refinish.
Re: harp ukulele project - Very Blue :(.
Bummer. I'm sure the refinish will be great. Good luck John.
Sorry John it is not to your liking. Will you do nitro on the second go around?
I will go back to em6000. I have done 4 instruments and have been happy. I should have stuck with it. Oh well you learn the most from your mistakes.
I waited long enough to update this build log. Those that have followed my post will note that after spray with EM7000 the instrument was way to blue. Not a tint but a very muddy blue finish. I usually try to follow a rule that when things go wrong put the tools down to think things through. I was so frustrated I went after the finish with an orbital sander. Not so bad while I was using 600 grit paper but a gin and tonic at dinner 200 grit sandpaper on the sander. Well, one can imagine. I ended up sanding a small section of the harp neck almost paper thin. Luckily I did not sand a hole in the side. I removed the back, in one piece, but thought that it was also bit thinner than I wanted. Not really bad, but luckily I had a koa back set without sides that was a very good match.
So after following my rule of putting the tools down, and resisting the urge to trash the instrument. I decided to glue a bit of veneer in the area where the side was thin and to build the new back. I also learned that a better way to remove WB lacquer is to use denatured alcohol and a scraper. I soaked a rag in the alcohol and placed it on an area of finish. This softened the lacquer and allowed me to remove it without removing wood.
I am just starting to put the whole thing back together. Hopefully this time it will turn out OK. I will use EM6000 to finish it the second time. The error on the EM7000 was probably mine. It builds much faster than the EM6000. Also care must be taken not to spray it thick. The EM6000 seems way more forgiving.
Here are some pictures about where I am. In the first picture you can see the patch.
Hi John, sorry to hear about the troubles you have been having. I wonder if you'd try with the EM7000 to thin it with alcohol by at least 20% I have done that on most of my most recent instruments to much better results than spraying or applying straight. NO orange peeling, less of a blue tint as well because it is not building as quickly. Just a thought. Hope it all works out well.
- Stevie Ray Vaughan
