Post by Kevin in California » Wed Mar 09, 2022 10:58 pm
Yeah Herman.
Pretty simple to put up and take down
I like it better than my old wood frame knock down booth
Yeah Herman.
Post by Kevin in California » Fri Apr 15, 2022 11:04 pm
Okay it's been 4 weeks and time to start finishing the finish. Very exciting stage
Post by John Parchem » Tue Apr 19, 2022 6:01 pm
Looks like it will level and buf out ... I love the color under finish.
Post by Kevin in California » Wed Apr 20, 2022 6:33 pm
Starting the buffing.
Actually finished the buffing today but right at the finish I bumped the edge of the purling area at the top and put in a dent just in the lacquer so that is being repaired as I write by drop filling thickened lacquer.
Always a bummer but an easy fix.
Post by John Parchem » Wed Apr 20, 2022 9:01 pm
I hate that at the end. It is looking good!
Post by Kevin in California » Fri Apr 22, 2022 1:01 pm
Gluing the bridge down. I use this fox bridge clamp but my arms are too big to get inside and screw on the clamping nuts so the bolts are there to position but the cam clamp and the wing bolts/clamps are sufficient. The fit to the top was near perfect.
I'll wait till tomorrow then drill out the bridge pin holes. Fit the pins and oh my I may be ready to put some strings on.
I will put my label in before strings, then the pick guard and finally set up at the nut and saddle. Whew.
