Rusty's PL 29 Antes Parlor
Re: Rusty's PL 29 Antes Parlor
Post by ken cierp » Sun Jul 14, 2013 6:22 pm
Did you do this test?
http://www.kennethmichaelguitars.com/NECKSET.html
You can't use the finger-board because it (generally) will not be flat enough. We are trying to determine if the connection between the neck and body produces a straight flat surface along the neck finger-board plane and the sound-board FB extension area.
rusty999
Post by rusty999 » Sun Jul 14, 2013 7:14 pm
Thanks , I will have a try at that in the morning as its after midnight here now.
Thanks for your patience
Rusty
rusty999
Post by rusty999 » Mon Jul 15, 2013 8:40 am
I had a read through that ken.
In my case I now think I have 2 separate issues. This morning I bolted on the neck to check for fit and while it slots in and bolts up perfectly I also find that when the neck is bolted in tight the top plane of the neck is pulled down into the mortise by about a 1/16th. First question is :Is it possible to enlarge the holes to allow the neck/ tenon be aligned perfectly with the top again and if so do i have to re fill the bottom of the holes, to have the bolts fitting tight again ? Pic enclosed
Would I be right in thinking I cant move forward with the other problem until I first get this sorted
Pic of the holes including the hole for truss rod to pass through
The bolts pull the neck down into the mortise by about 1/16th
Post by ken cierp » Mon Jul 15, 2013 9:29 am
Definately elongate those holes --this actually should have been done before you routed channels and installed the trim. The idea is to get the parts to fit before working on the bling.
rusty999
Post by rusty999 » Mon Jul 15, 2013 12:21 pm
Ok Enlarged the holes now and all tightens up perfectly and I have a level playing field around the joint of mortise/tenon.
But , the old problem remains. I set the un fretted fretboard on top of the neck where it should be--not glued obviously-- and lay the straight edge along it to reach where the bridge will eventually be.
Theres no gap whatsoever along the top where the fretboard extension sits--the fretboard sits perfectly flat. But , the straight edge hits the bridge about half way up its depth.Lets put it this way -if it was 1/8th higher it would be about right. I assume the frets would raise the straightedge slightly but even then I'm doubtful if it would be enough
So, is the only answer to tilt the heel back by removing material from it ?
That was definitely something I was hoping would not happen.
Any advise is much appreciated
Rusty
Post by ken cierp » Mon Jul 15, 2013 12:29 pm
What does that mean?
Picture please -- straight edge on the fingerboard plane of the neck (no finger-board) along the full length and the finger-board extension area. You are getting the finger-board involved here too early.
My guess right now is that you do not have a straight line and there is no angle machined on the neck heel.
rusty999
Post by rusty999 » Mon Jul 15, 2013 1:29 pm
Best i can do with a bad camera lens but if you need more please let me know
Its a pretty straight line
Thanks
