Thanks Bob. I got the binding scraped today and it's ready to sand the top.naccoachbob wrote:Tim, this one is really coming along nicely. It's gonna be really good.
Congrats.
Bob
D-28 Style Brazilian and Adirondack
Re: D-28 Style Brazilian and Adirondack
Looking gooder all the time.
I got the top sanded and sealed and have pore filled the body (System 3 SB-112 epoxy). That has dried and I am spraying now. This will be my first with Cardinal Nitro Lacquer. First impression is the "after smell" is less intense that with the Mohawk I have used in the past. But I've only sprayed the vinyl sealer so far.
- 48 Top Sanded and Sealed.jpg (344.55 KiB) Viewed 668 times
- 49 Pore Filled.jpg (326.99 KiB) Viewed 668 times
Some gorgeous wood.
Have you used the system 3 before?
Yes. Only pore fill method I've used since I've been building ( I have some Timbermate but haven't tried it yet). The wood is beautiful. The grain swirls through. It really came out after sanding it. And the box has a beautiful sustained tone when tapped. Hope that translates when strung up.
Here it is with 12 coats of nitro lacquer. Tomorrow I will level sand with 600, spray 3 more coats and let it cure for a week before final wet sanding and buffing out. The Cardinal Lacquer is supposed to harden in 7 days compared to other formulas (3-4 weeks). WE SHALL SEE.
- 50 12 Coats of Lacquer.jpg (417.9 KiB) Viewed 642 times
- 51 12 Coats of Lacquer.jpg (416.78 KiB) Viewed 642 times
- 52 12 Coats of Lacquer.jpg (436.38 KiB) Viewed 642 times
Tim that looks amazing. Very clean and tasteful work......
