Tom's KMG L-00
Re: Tom's KMG L-00
Post by Dave Bagwill » Wed May 11, 2016 1:19 pm
So - does it sound like a guitar or not? The better test is when it is completely set up, and we will post a vid clip at that point, up and down the neck.
John J
Re: Tom's KMG L-00
Post by John J » Wed May 11, 2016 1:51 pm
It most certainly does sound like a guitar. And a nice sounding one at that! Nice job.
JJ
Re: Tom's KMG L-00
Post by Kevin in California » Thu May 19, 2016 12:14 pm
Just watched the vid Dave, sounds really really good. That is going to be a fun one to play for sure!
Re: Tom's KMG L-00
Post by Dave Bagwill » Thu May 19, 2016 12:33 pm
we've got a little backbow on the neck that I'm working on, then we'll finish up and play a tune.
Renee Labordus
Re: Tom's KMG L-00
Post by Renee Labordus » Thu May 19, 2016 8:05 pm
I will be very happy if the 00 I am currently building (KMG) is going to sound like that.
Re: Tom's KMG L-00
Post by Dave Bagwill » Sun May 29, 2016 4:01 pm
Ken gave me a tip concerning the backbow. A friend gave me a 1"x48" heating blanket which I plugged into the kmg controller. I laid the blanket on the bench, covered it with aluminum sh
This removed the backbow and gave a very slight relief; the string tension brought the relief up to an acceptable figure.
So I think we are good to go.
Re: Tom's KMG L-00
Post by John Parchem » Mon May 30, 2016 11:18 am
Good fix! Just to learn from your experience I have a few questions: How long did you heat it and leave it clamped? Do you think the back bow came from compression from the frets or do you think the wood was not quite stable? Also did you use a one way truss rod?
