An HD-28 style for Tom T
Re: An HD-28 style for Tom T
Great thanx guys. I think I would like to do one on my next build !
Radiused the bridge, routed out the saddle slot and did the final sanding on the bridge. Drilled the tuner holes and made the final neck set check. Will be gluing on the neck and bridge tomorrow and attaching the tuners. Friday I'll do the final setup and then it will be done.
- 75 Bridge Slotting Jig.jpg (265.23 KiB) Viewed 536 times
- 76 Bridge Slot Cut.jpg (243.42 KiB) Viewed 536 times
- 77 Radiusing the Bridge.jpg (236.68 KiB) Viewed 536 times
- 78 Radius Progress.jpg (247.66 KiB) Viewed 536 times
- 79 Bridge Radiused.jpg (229.09 KiB) Viewed 536 times
- 80 Tuner Holes Drilled.jpg (208.87 KiB) Viewed 536 times
- 81 Final Setup Check.jpg (259.56 KiB) Viewed 536 times
So, I got the neck and bridge on and shape and fitted the nut (still have to cut slots), and I have the saddle fitted to the slot.
- 82 Neck Glue Up.jpg (242.07 KiB) Viewed 521 times
- 83 Bridge Glue Up.jpg (253.2 KiB) Viewed 521 times
- 84 Nut Radiusing.jpg (209.03 KiB) Viewed 521 times
- 85 Nut Radius.jpg (201.09 KiB) Viewed 521 times
- 86 Nut Shaping.jpg (227.13 KiB) Viewed 521 times
- 87 Nut Shaped.jpg (189.72 KiB) Viewed 521 times
The guitar looks great and ready to string up. I use the same jig to route the slot in the bridge. I have been doing it on the guitar, but now I see that I can still place the bridge, measure the saddle location but then route the slot off the guitar.
Yeah, I like doing it off the guitar and keeping the equipment away from the top (makes me too nervous there). I have the work board elevated on two 2" high riser blocks in the corners and the jig held in place with the 2 cam clamps. I use double sided tape to hold the bridge in place (the bridge location is outlined on the work board so I get the location the same each time). My router is hooked up to a foot pedal. Then I have at it.johnparchem wrote:The guitar looks great and ready to string up. I use the same jig to route the slot in the bridge. I have been doing it on the guitar, but now I see that I can still place the bridge, measure the saddle location but then route the slot off the guitar.
Leveling, crowning and polishing the frets.
- 88 Fret Leveling.jpg (254.26 KiB) Viewed 562 times
- 89 Crowning and Polishing Supplies.jpg (247.33 KiB) Viewed 562 times
- 90 Fine Cowning.jpg (219.73 KiB) Viewed 562 times
- 91 Rough Crowning.jpg (221.3 KiB) Viewed 562 times
K&K Pure Mini pickup installation.
- 92 Pickup Installation.jpg (251.09 KiB) Viewed 562 times
- 93 End Jack Reaming.jpg (225.42 KiB) Viewed 562 times
- 94 End Jack Feeding.jpg (254.91 KiB) Viewed 562 times
- 95 Fastening Hardware.jpg (239.38 KiB) Viewed 562 times
- 96 Tightening Things Up.jpg (203.83 KiB) Viewed 562 times
- 97 End Jack Cap.jpg (194.09 KiB) Viewed 562 times
- 98 Transducer Glue Up.jpg (235.25 KiB) Viewed 562 times
