Tim Crain's J185
Re: Tim Crain's J185
Nice and uniform, looks really good.
I made my self a turn table which made shooting the burst much easier. Holding the guitar with one hand while shooting with the other is really difficult, any little movement shows up as a BIG change in the width of the shading. Having the guitar staying in place eliminates a big part of that problem. I had asked in an earlier post about strap buttons and got no responses. I had mentioned that I want buttons on mine and had gone to the finished gallery to see what others had done and noticed that all that I looked at did not have strap buttons. I am jumping between doing the tapered end pin or fabricating a nice version of the screw on type. Any thoughts would be appreciated and thanks for the encouraging comments on the finish. I should be able to spray the last coats of clear this weekend then the long wait until wet sand and rub out. Thanks again, Tim
Tim I think you've done a great job. Whatever you decide on the strap buttons I'm sure will be done with class. The end pin is more traditional.
Tim, All my guitars have strap buttons, or end pin jacks. I do the tapered push in pin, I believe ulitmatley it will be stronger.
If you are doing a button on the neck, of course you will need to do a screw in. If you are sure the guitar will never be hung around a neck, then leave them off, but its nice to have the versatility. You don't usually see them on a classical
Thanks for the input on the strap buttons. I think I will go with the traditional tapered pin.........hummmm, probably should have done that before we shot the finish. I still have some more coats of clear so I will fit that before the final spraying. I think I should be able to finish the spraying this week end so just need to do the inlay on the bridge to mask the placement pin holes, build a truss rod cover, rough out the nut then rub out, polish and put it all together. Looks like we should have this one wrapped up in a few more weeks...... now what am I going to build?? Thanks for all the help along the way, this forum really saved me a lot of learning from mistakes.
Just wanted to post an update on my J185 project. The weather was great yesterday so I was able to wet sand and buff out the finish. A couple of minor things to fix but all in all I am very pleased. I still need to polish, the finish looks really nice. I took it down to 2000 during the sanding which make the rub out very easy. I will need to cut around the bridge mask with a razor (I'm sweating that part, any words of wisdom?) then remove the mask, glue on the bridge, string up and do the set up. It has been a long road but I can see the end now. I'll keep posting till we hit the finish line.
- IMG_1930.JPG (129.3 KiB) Viewed 878 times
- IMG_1932.JPG (133.38 KiB) Viewed 878 times
- IMG_1936.JPG (120.35 KiB) Viewed 878 times
- IMG_1934.JPG (109.71 KiB) Viewed 878 times
- IMG_1938.JPG (137.16 KiB) Viewed 878 times
- IMG_1933.JPG (139 KiB) Viewed 878 times
