D-28 Style Brazilian and Adirondack
Re: D-28 Style Brazilian and Adirondack
Post by peter havriluk » Mon Jun 17, 2013 9:55 pm
Thanks!
Post by Tim Benware » Mon Jun 17, 2013 10:41 pm
Installed the Ivoroid End Wedge.
26 End Wedge Slot.jpg (403.35 KiB) Viewed 399 times
27 End Wedge Installed.jpg (405.56 KiB) Viewed 399 times
Post by TonyinNYC » Tue Jun 18, 2013 8:51 am
Excellent looking build! I noticed a few problems that I feel I should point out in the interest of building a pre-war "cannon".
You used reversed kerfed linings and Martin uses triangular linings, so therefore, this guitar can never sound like a pre-war Martin. I hope you like being disappointed, because you ruined the whole guitar by using those modern techniques as well. Martin didn't use vacuum bags to glue their braces on the pre-war dreads either, so you pretty much screwed the pooch on this one.
OK...I'm just joking. But it is fun to poke fun at the traditionalists sometimes!
Post by Tim Benware » Tue Jun 18, 2013 2:22 pm
TonyinNYC wrote:pre-war "cannon". Martin didn't use vacuum bags to glue their braces on the pre-war dreads either.
Well - I never said this one was going to be a pre-war and I was at least half right on the bracing. Go back to the bottom of page 2 and on page 3 to see where I glue up the top bracing using the go bar deck using HHG:)
Post by TonyinNYC » Tue Jun 18, 2013 3:24 pm
You used HHG? Then it will be fine.
Post by Tim Benware » Tue Jun 18, 2013 11:12 pm
Today's progress (some of it anyway). Back is ready to glue and I'll do that in the morning.
28 Top Glue Up.jpg (409.91 KiB) Viewed 579 times
30 Top On.jpg (365.95 KiB) Viewed 579 times
31 Inside Top.jpg (371.6 KiB) Viewed 579 times
Post by Tim Benware » Wed Jun 19, 2013 8:14 pm
The back is on and the neck is ready to inlay the headstock logo.
32 Back Glue Up.jpg (442.07 KiB) Viewed 568 times
33 Back On.jpg (420.46 KiB) Viewed 568 times
34 Neck.jpg (401.5 KiB) Viewed 568 times
