harp ukulele project - Gluing down the bridge...
Re: harp ukulele project blog
Post by TonyinNYC » Mon Jul 09, 2012 9:28 am
No, no, no, no, no. You have too many cam clamps and they are all crowded together. Please send some of them to my "Home for Cramped Clamps" and I will make sure they have room to roam free.
Happy clamps make happy guitars John!
Nice work. It's going to be cool when done.
kmatsu
Post by kmatsu » Mon Jul 09, 2012 10:50 am
johnparchem wrote:I am not sure that one can ever have enough cam clamps. I use them a lot.
John --- I think you're right --- here's that cover of Jeff Traugott's use of cam clamps --- he's got 35 on this guitar (he's got you beat there!)!!!
Post by John Parchem » Tue Jul 10, 2012 9:00 am
I knew I should have bought a bunch clamps more when I was at the hardware store. Mine are too far apart. I did think about that. I glued with the top down, fully supported. The rim is very stiff longitudinally, so I think my upside down method may have more even clamping pressure. He does appear to be using enough clamps.
Thanks for posting the cover.
kmatsu
Post by kmatsu » Tue Jul 10, 2012 10:14 am
johnparchem wrote:I knew I should have bought a bunch clamps more when I was at the hardware store. Mine are too far apart. I did think about that. I glued with the top down, fully supported. The rim is very stiff longitudinally, so I think my upside down method may have more even clamping pressure. He does appear to be using enough clamps.
John, I think you're just fine with how you clamped it, and with the number of clamps you used --- I actually just posted the photo as a kind of funny comment on your "can't have too many clamps" comment! (I'm not even sure whether or not Jeff actually uses that many clamps, or if it was just for the look of the cover photo --- I'll have to check with the article...).
Also, I thought I had a lot of cam clamps, and I only have 16 (8 small and 8 large)!!! But I use the go-bar deck now to glue on the tops and backs, so don't really need more. But I love cam clamps and still use them a lot...
Post by ken cierp » Tue Jul 10, 2012 10:45 am
Cam-clamps rule!!
Of course I am partial to "tools with motors" but I still use the cam-clamps I made a zillion years ago from the plans in Irvine Sloane's "Classic Guitar Construction" book.
Post by John Parchem » Tue Jul 17, 2012 1:42 am
I managed to make a bit of progress this weekend. I successfully trimmed the top where the spruce inlays into the peg head. I had the peg head veneer already routed so I had to trim the top to the right shape in the right place so that it would match up and allow the peg head to be glued to the harp neck. I had a good template and made the shape but just a tad long and slowly sanded back the top until it just fit the rebate.
Before gluing the peg head to the harp neck I played around getting it closer to the final shape. I used my slide vise with a sanding drum to carefully sand the arch down a bit. (Actually it did not take very long before I got rid of the vise and just help the part eyeballing the lines I wanted.)
I was finally able to close the box and trim the edges back.
On to the bindings
Post by TonyinNYC » Tue Jul 17, 2012 6:20 am
Very nice looking box!!
