I promise the last post for a bit as I mostly have tedious finish prep work left ... But yesterday I installed the truss rod and carved the neck.
I generally have the truss rod flush but went just a tad deep with my channel so I planed a bit of spruce to fit in the channel. and wicked in a touch of CA and planed it flush.
Also note I am all prepped to glue on the fret board. I have three 1/32 index pins to assure alignment. Also I have some strips of purfling wood on the edges pf my cauls to force the edges of the fret board down.
Looks like I am getting a lot of squeeze out.
Never to many clamps
I decided to carve the neck with a circular arc. I drew the squared dimensions for the 1st and 6th fret, found the arc with a compass and finally drew tangent lines to determine the diminsions of my first facet. I then transferred the facets lines to the neck.
I use a spoke shave to cut the initial facet. It goes really clean. I know some draw in the secondary and tertiary facets, but for a circular arc they are easy to see on the neck. So I just attack them with the spoke shave as well. At some point I switch to sand paper to remove the remaining facet lines.
I go at the heal with a nice rasp. At first it seem slow put really it goes pretty fast as well. In the following picture I am about 50 minutes into the carving process.
Here are some pictures prior to the start of finish prep.
12 String SS Falcate braced Ziricote\spruce guitar.
Re: 12 String SS Falcate braced Ziricote\spruce guitar.
John, thanks for posting all the photos and descriptions. You make it look so easy. It is going to be a beautiful guitar.
Jim
Jim
The guitar looks great with the koa purfling line. Can't wait until you string her up and we can hear sweeet soounds.
One last post before finishing.
I added diamond fret markers, I put a back veneer on the head stock, made my logo, and drilled for the tuners.
I had to cut out my logo twice; I accidentally made a ukulele sized logo.
I have shown this before but I cute the moon from mother of pearl.
The hawk and branch are cut from ebony (fret board cutoffs)
And no I have not found a good use for the pearl hawks
John you sure have gotten good at cutting out your logo, I remember when you did your first one!
This guy was in our back yard earlier this week.
- 005.jpg (84.25 KiB) Viewed 734 times
Did you break out the BBQ?
