An HD-28 style for Tom T
Re: An HD-28 style for Tom T
Post by Tim Benware » Fri Jan 23, 2015 11:01 am
So, customer wanted his initials on the back of the headstock and a custom headstock logo (West Virginia) which have been installed. I also got the frets in and will glue up the FB today.
55 Initials Inlay.jpg (214.84 KiB) Viewed 1071 times
56 Routing the Insets.jpg (252.49 KiB) Viewed 1071 times
57 Checking Positioning.jpg (270.44 KiB) Viewed 1071 times
58 Headstock Inlay Complete.jpg (209.14 KiB) Viewed 1071 times
59 Fret Press.jpg (237.43 KiB) Viewed 1071 times
60 Frets In.jpg (238.66 KiB) Viewed 1071 times
61 Fret Ends Trimmed and Beveled.jpg (214.27 KiB) Viewed 1071 times
Post by Tim Benware » Fri Jan 23, 2015 5:52 pm
I attached the FB to the neck and roughed out the bridge. I do the final thicknessing and sanding once the neck is attached to the body so I can get the neck angle precise.
62 FB Glued On.jpg (280.77 KiB) Viewed 1063 times
63 Bridge Black.jpg (271.82 KiB) Viewed 1063 times
64 Holes Drilled.jpg (225.51 KiB) Viewed 1063 times
65 Saddle Slot Located.jpg (215.22 KiB) Viewed 1063 times
66 Sanding the Wings.jpg (254.6 KiB) Viewed 1063 times
67 Wings Profiled.jpg (249.81 KiB) Viewed 1063 times
68 Bridge Profiling.jpg (266.5 KiB) Viewed 1063 times
69 Roughed in Bridge.jpg (275.99 KiB) Viewed 1063 times
Post by Tim Benware » Tue Jan 27, 2015 11:32 pm
Taped off the top for spraying and stained the neck. This is my first time staining a neck. It is wet in the pick and dries more evenly (this is the second coat.
71 Masked for Spraying.jpg (218.6 KiB) Viewed 827 times
72 Neck Stained.jpg (207.77 KiB) Viewed 827 times
Post by Tim Benware » Sun Feb 01, 2015 11:58 pm
In the booth for some nitro.
73 Spraying Body.jpg (210.29 KiB) Viewed 811 times
74 Spraying Neck.jpg (201.72 KiB) Viewed 811 times
Paul C
Post by Paul C » Mon Feb 02, 2015 6:45 am
Tim your guitar looks great. Love the herringbone on top. Do you have to prebend it before installing?
Post by Tim Benware » Mon Feb 02, 2015 10:29 am
Paul C wrote:Tim your guitar looks great. Love the herringbone on top. Do you have to prebend it before installing?
Yes. I can bent it but I now just get the stewmac pre-bent, it's worth it to me to save the time for the extra cost.
Post by ken cierp » Mon Feb 02, 2015 11:11 am
Here's a little purf bending tutor
