Steve's KMG 000-12 kit
Re: Steve's KMG 000-12 kit
Post by Kevin in California » Fri May 30, 2014 6:21 pm
Ah I didn't realize this was going to be a slot head guitar. Very nice.
Post by Dave Bagwill » Fri May 30, 2014 6:42 pm
And I did use tight fitting shims to prevent ragged holes on the inside.
Post by John Parchem » Sat May 31, 2014 2:28 am
Dave Bagwill wrote:And I did use tight fitting shims to prevent ragged holes on the inside.
You knew one of us would ask? Looking good!
Post by Dave Bagwill » Sat May 31, 2014 2:31 am
johnparchem wrote:You knew one of us would ask?
We are an eagle-eyed bunch around here! :-)
Post by Dave Bagwill » Wed Jun 04, 2014 3:02 pm
We're going to spray Steve's finish on tomorrow, so today we sanded to 320, laid on a good coat of zinsser sealcoat, let it dry, then sanded down to the wood, leaving shellac in the pores. I just put on the second coat of sealcoat, will let it dry an hour or so and then remove it, and the pores will be filled with clear unwaxed shellac. Looks shiny right after brushing it on!
Post by Dave Bagwill » Tue Jun 10, 2014 12:54 am
Picture of Steve spraying on a coat of finish in his shop, and a pic of the guitar after a coat has been sprayed.
It's a water-based finish that had no noxious fumes, sprayed on easily.
Post by ken cierp » Tue Jun 10, 2014 12:08 pm
Looking Good
but
Water Borne coating mist/over spray can kill you dead (maybe not as many brain cells at first) just like the solvent coatings -- at the very least a particle mask should be used!
