Tim Crain's J185
Re: Tim Crain's J185
I can't help but see the defects now and I like the look of a nice sunburst so I will take another shot at it. I am really glad that I had put down the 4 coats of clear first, it made a much easier job of removing the tinted coats. I sprayed the burst while holding the guitar by the neck, I had done that in the past but it makes it double difficult because not only is the gun moving but the guitar tends to move as well. When I re shoot it I plan on having the guitar laying on a lazy susan that way I only have to deal with the movement of the gun. With the guitar laying flat I should be able to angle the shot to get a very subtle blend of shading. I really dislike the sunburst where you see 3 distinct lines of color ala Fender, I like the ones that has a very gradual transition in the shading. Not having the sunburst quite as wide is also another reason for the re shoot. Since I am upgrading my spray gun arsenal I would like to offer up my old guns to who (whom??) ever might need them. They are not great but have managed to spray a number of guitars and motor cycles over the years with acceptable results(see pics) . Just email me and I will gladly pack them up and ship them free of charge, Merry Xmas!
- IMG_1736.JPG (133.77 KiB) Viewed 616 times
- IMG_1734.JPG (131.58 KiB) Viewed 616 times
- Montana 8 of 07 020.jpg (218.59 KiB) Viewed 616 times
- Montana 8 of 07 025.jpg (155.56 KiB) Viewed 616 times
- motor bikes 012.jpg (151.66 KiB) Viewed 616 times
- DSCF0023.JPG (200.07 KiB) Viewed 616 times
When I do sunbursts I use a Pasche airbrush and very thin material. It takes a long time and a lot of coats, but it is relatively easy to make all transitions smooth.
John's idea of undercoating with amber is excellent. I probably wind up doing that without thinking about it.
The clear undercoat is a good thing, if you have to sand it again. There are several way to do it, but my sunbursts in short:
-clear undercoat(s)
-amber or yellow on the whole top
-brown with a bit black spraying inside out
-red spraying outside in
-spray the color very thin at a time
http://hermanarendsenguitars.nl/foto/ro ... big%20.jpg
2cts
-clear undercoat(s)
2cts
Well I am taking another shot at the sunburst today, should be about 70 and calm here so we'll see what we can do. I'll post some pics when I'm done. I was looking at the pictures in the gallery section and noticed that most of the finished instruments lacked strap buttons. I am wanting the strap buttons on mine and was looking there to see what others had done when I realized that most don't have them. I am debating doing the tapered end pin or just the good old screw on type though I would most likely make the button part myself, ebony or curly maple. Any thoughts would be appreciated. Thanks, Tim
- IMG_1717.JPG (140.43 KiB) Viewed 604 times
- IMG_1721.JPG (128.68 KiB) Viewed 604 times
- IMG_1732.JPG (133.13 KiB) Viewed 604 times
Sunburst re deaux
Well I got the burst shot and protected with a couple coats of clear. This is much more to my liking. I think I will have to spray a couple of more coats next week then let it sit for a couple of weeks then sand and rub out. I can at least see the finish line now!!
- IMG_1861.JPG (126.06 KiB) Viewed 593 times
- IMG_1859.JPG (162.31 KiB) Viewed 593 times
- IMG_1858.JPG (136.24 KiB) Viewed 593 times
- IMG_1857.JPG (130.5 KiB) Viewed 593 times
Thank you Dave. I can tell you now that in the future I will do everything in my power to avoid having to shoot another one. I guess it wasn't that bad but having to do it twice sure makes it seem like a LOT MORE WORK!! Just shooting clear is SOOooooooo easy. This is the first time that I have used the Cardinal lacquer and I sure liked it. It seems to build faster than the McFadden, drys really quick as well. Let's see how it rubs out. I'll keep you guys posted.
