D-28 Style Brazilian and Adirondack
Re: D-28 Style Brazilian and Adirondack
Post by Tim Benware » Mon Jun 17, 2013 4:34 pm
Got the braces carved and scalloped. Thought I took a pic of the top being done but I guess I didn't (anyway it's done). And I got the side reinforcement strips in.
19 Carving the Back Braces.jpg (441.54 KiB) Viewed 419 times
20 Side Reinforcement Glue Up.jpg (430.14 KiB) Viewed 419 times
21 Side Reinforcements.jpg (397.49 KiB) Viewed 419 times
Post by Tim Benware » Mon Jun 17, 2013 4:39 pm
Thicknessed the fretboard, cut the fret slots, tapered and radiused the board, inlaid the markers, pressed in the frets and attached the board to the neck (truss rod included :))
22 Fret Slot Cutting.jpg (389.39 KiB) Viewed 419 times
23 Slots Cut.jpg (412.06 KiB) Viewed 419 times
24 Pressing In the Frets.jpg (463.25 KiB) Viewed 419 times
25 Fingerboard Glue Up.jpg (454.57 KiB) Viewed 419 times
Post by Kevin in California » Mon Jun 17, 2013 6:02 pm
Looking more like a guitar all the time.........
Post by Dave Bagwill » Mon Jun 17, 2013 6:18 pm
Very nice work as usual!!
Post by peter havriluk » Mon Jun 17, 2013 6:52 pm
Do you mind a question over one of the photos? Okay, my lack of experience is on show here: What purpose is served by having a sequenced block of wood holding frets 1 -22, installed in order, I'd guess? I hadn't thought that frets needed to be bent individually for each distinct position on the fretboard.
Thanks very much.
Post by Dave Bagwill » Mon Jun 17, 2013 7:24 pm
Pete - the length is different for each fret. You're right that the radius for each fret is the same, except in those few fretboards that have a compound radius.
Post by Tim Benware » Mon Jun 17, 2013 9:29 pm
Yes, what Dave said. I cut all my frets first and sequence them in the block (BTW the holes in the block are not drilled the same depth which is why they look like they go up and down in length). I have two sides because sometimes I do 2 sets and set them aside and come back at a later time. It's just a convenience for me but obviously not a necessity.
