All braces now glued down.
I started some carving today
A new OM starting
Re: A new OM starting
- 20231217_150858.jpg (133.87 KiB) Viewed 879 times
I've made a bunch of progress in the past week or so.
Carved the braces, attached the top, routed it flush.
Installed a curly Koa endwedge.
Inlayed my logo on an ebony headplate.
And today, I bent the curly maple binding and glued plastic BW purfling to one piece.
- 20240127_105550.jpg (394.61 KiB) Viewed 840 times
- 20240127_110431.jpg (97.37 KiB) Viewed 840 times
- 20240127_150734.jpg (307.87 KiB) Viewed 840 times
- 20240127_153815.jpg (117.48 KiB) Viewed 840 times
- 20240127_153805.jpg (123.14 KiB) Viewed 840 times
- 20240130_134824.jpg (91.09 KiB) Viewed 840 times
- 20240131_130623.jpg (100.98 KiB) Viewed 840 times
- 20240131_134408.jpg (90 KiB) Viewed 840 times
- 20240131_144912.jpg (84.49 KiB) Viewed 840 times
- 20240201_125833.jpg (105.87 KiB) Viewed 840 times
- 20240201_125846.jpg (134.37 KiB) Viewed 840 times
- 20240201_161911.jpg (212.27 KiB) Viewed 840 times
Kevin, I too really like Spanish Cedar for necks (and linings). One thing I learned from Sergei De Jonge when I was at his school/shop was, if you want a thin neck like you can get with Mahogany, you need a little carbon fiber reinforcement in the neck besides the trussrod. Not a lot, but some. Otherwise you should leave the neck a few mm.s thicker. Check out Sergei's website, he's an internationally known luthier and has trained hundreds more at his school.
Brent
Brent
Thanks Brent
So far I haven't had a Spanish cedar neck on a steel string have a problem. I've been using aluminum channel truss rods.
The one I'm building now is using a Stewmac rod. I guess will see if it's stiff enough.
Fret board made. Bound with cut offs of the same blank and b/w plastic purfling glued in there.
Then today I cut the binging/purfling channels. That went well. I'll be gluing in the scheme over the next couple of days.
- 20240209_163755.jpg (544.28 KiB) Viewed 821 times
- 20240210_111407.jpg (262.01 KiB) Viewed 821 times
- 20240210_133424.jpg (150.35 KiB) Viewed 821 times
- 20240210_133441.jpg (164.16 KiB) Viewed 821 times
The binding and purfling is in. I didn't have to alter the channels at all after the routing. I got a nice even cut.
I glued in the plastic purfling first using special glue for bonding plastic to wood(or plastic to plastic).
Once that was dry I scraped away any excess dry glue from squeeze out. Then I taped in the binding, fitting the joints at the butt end first and then the neck end. When it was all taped in tight I wicked in CA between the tape, top and sides. Once dry I pulled the tape and the wicked in more CA where the tape had been.
Low pressure process.
I just finished scraping it all flush. I installed the binding about .010" proud on top and sides so there was a bit os craving to do. I started out with .085" binding so it's now about .075" and I think looks just right. Combination binding and side purfling is .250" tall.
Now I'll focus on the neck for awhile.
- 20240215_141723.jpg (264.22 KiB) Viewed 816 times
- 20240215_141731.jpg (318.9 KiB) Viewed 816 times
- 20240215_141740.jpg (259.5 KiB) Viewed 816 times
- 20240215_141750.jpg (241.13 KiB) Viewed 816 times
- 20240215_141802.jpg (316.88 KiB) Viewed 816 times
Exquisite bindings n purflings!
I drool every time I see photos of your shop or Parchem's. Like your fixture for routing the rabbets.
