Glue and torrefied wood
Hans Mattes
Re: Glue and torrefied wood
Post by Hans Mattes » Fri Apr 01, 2022 12:22 pm
I've often found that the first (and, sometimes, the second) application of Tru-Oil looks "splotchy" or uneven. The duller areas seem to occur where the wood absorbs the TO more readily than in other areas. Once I've applied three or more coats, the TO seems to form a surface film with a smooth appearance. Once the surface film is complete, I may add several additional coats of TO to the back and sides, but will only add one to the soundboard in order to minimize damping. FWIW.
Post by Dave Bagwill » Fri Apr 01, 2022 12:27 pm
Thanks Hans. Good thing to keep in mind.
Post by John Parchem » Fri Apr 01, 2022 1:13 pm
I used torrified wood once, it was a pain and in the end I was not wowed by it characteristics. It sounds like you are moving forward now with good results.
Post by Dave Bagwill » Fri Apr 01, 2022 1:49 pm
We'll see what it sounds like. It is more difficult to work with. And I'll have to see if the bridge stays on!
Post by Dave Bagwill » Thu May 05, 2022 3:28 pm
So - the TO finish worked just fine on the back and sides.
BUT - the TO will not stick to the torrefied WRC. So I had to remove the TO from the top, and am refinishing with a different product that is working well. In this case, Watco tung-oil 'one step' finish. This is not straight tung-oil, it has other additives, but tung oil is the base. Goes on nicely, recoat after 24 hours, no sanding between coats, and it seems to level itself. I like it, and am just building a few coats for a bit of gloss.
Post by Dave Bagwill » Wed May 11, 2022 3:40 pm
Ok, the bridge will have been gluing for 24 hours at 4 pm this afternoon.
So - tomorrow morning will be the first stringing-up.
Then we will see if the *9&^97%@#% thing stays on. Pardon my language. :-)
It will be fun to hear it for the first time, as you all have experienced..
Post by John Parchem » Fri May 13, 2022 11:50 am
Did it stay on??
