8 string 'newzouki'
John J
Re: 8 string 'newzouki'
Post by John J » Sat Sep 03, 2016 10:48 am
Nice bridge. Is that saddle slot oversized or is it just the photo?
JJ
Post by Dave Bagwill » Sat Sep 03, 2016 11:07 am
Yeah, it's a full 1/4" and it is parallel to the front of the bridge - I did some research as to why that is the recommendation, and mainly it's because of mandolin-family instruments based on an old Martin series. And like I said previously, the slot is at an 8* angle.
It's a plain-Jane instrument, so a little at the bridge and the headstock plate will help a little bit; this is a prototype anyway so cosmetics are not a priority.
Post by ken cierp » Sat Sep 03, 2016 4:15 pm
Pretty cool Dave!
Actually a 3/16" or 1/4" saddle is a nice improvement when it come to precise intonation. Here's one I built about 40 years ago it has a 1/4" saddle and note it is also angle. So is it over sized or the right size? Got this recommendation from Don Teeter ----- And check out the Ovations -- I think Kaman got that part right.
Post by Dave Bagwill » Sat Sep 03, 2016 8:09 pm
I know that Doolin is a big fan of the 1/4" saddle as well.
Herewith a couple of pix just for the record - the contractor's clamp holds the veneer in place and also provides a straight surface to hold your knife against; that's one way to do it and it works if you are careful - some knives will wander. I normally just use the clamp to hold the veneer in place against the edge of the mdf then use the stewmac tool to rip what I need.
And I did have to bend the .060" binding just for safety, around the guitar side of the thing. But at .060", the bending took about 30 seconds total.
Post by John Parchem » Sun Sep 04, 2016 2:47 pm
I am getting excited to see how your guitar turns out finished. I once use .060" black fiber for binding it was a joy to work with. I was able to bind with only two pieces so I only had one visible joint.
Post by Dave Bagwill » Mon Sep 12, 2016 3:37 pm
Allrighty - I'm hoping that these spots of color will juice up the plain jane instrument = headstock, endwedge, end of fretboard treatment, bridge - all bloodwood and gives the appearance of having a theme, at least. Ah - actually the endwedge is Bubinga.
The cat - yeah you've seen her before; she loves the shop.
My wife is holding a rat that the cat brought into the shop; she already had gardening gloves on so I allowed her to pick up and deliver the rat.
I clamped the fb to the neck and just used a 3/16" file to cut the nut slot - since I hold the file against the fb end, I end up with a slot exactly parallel to the fb end. Downside is it takes 10 minutes.
Gluing on the fb this afternoon - probably going to use epoxy.
Post by John Parchem » Mon Sep 12, 2016 8:13 pm
Proud cat! doing her job. I think the instrument is looking great. I love the color contrast.
