Building a workbench
Re: Building a workbench
Post by Dave Bagwill » Thu Mar 31, 2016 11:43 am
Nice work Kevin! What is your procedure for flattening the top with a plane?
Post by Kevin in California » Thu Mar 31, 2016 11:51 am
The instructions on the back of the cereal box say to hand plane straight across the top first, concentrating on the high spots, but then going for flat, then diagonally one way, then diagonal the opposite way, then plane the full length.
I sort of did this on the bottom, but didn't try to get it perfect. I should work, according to the instructions on the box of Post Toasties. :)
Post by Herman » Thu Mar 31, 2016 12:56 pm
You made an excellent bar with that stool. I thought you quit drinking! ;-)
Paul C
Post by Paul C » Thu Mar 31, 2016 5:44 pm
I think you should shape the top like a guitar body. Save on space and not so sharp corners .
Brad Hall
Post by Brad Hall » Fri Apr 01, 2016 2:15 am
Nice work. I would add a piece of 1x4 hardwood on the ends. Eliminate tendency to split when clamplig and stabilize the deck. What vice are you using?
Post by Kevin in California » Fri Apr 01, 2016 11:57 am
Spent a couple of hours last night hand planing the top flat, then used the orbital sander on it....that made it look better but it is probably not as flat now :( Oh well, it looks nice.
The finished thickness of the top is right at 3".
I will put a face on the right end, not sure I will on the left end. I have two cabinet makers vises coming today from Grizzly....one for the end, and one for a face vise on the left front.
Mixed reviews on this vise, but a good price point and for what I do, it will be nice to have two vises for the $$
Post by Dave Bagwill » Fri Apr 01, 2016 1:57 pm
Are you going gloss or semi-gloss? :-)
