Manzer wedge
Re: Manzer wedge
How are you accounting for the spherical shape of the contoured back plate?
Re: Manzer wedge
Once the sides are trimmed, I will trace their outline onto the joined and braced back, because the back will be a little bit larger than an unwedged guitar. Then using blocks and shims in the megamold, I will get the plane of the rims where it needs to be and use the radius bar.
Re: Manzer wedge
Any other thoughts from anyone before I start making shavings?
Re: Manzer wedge
Just waiting to see how your methodology works out (not clear to me) -- don't forget that the highest point on the back side edge of the rim is the inner most waist curve apex.
Re: Manzer wedge
I am trying another method this morning and see if the results are the same, before I start a-cuttin'.
Re: Manzer wedge
Hey Dave. Ditto to Ken, I don't see your method and its trouble. Friend Kevin wrote in september that his view would be simple. So mine too. If I would encounter this: I would glue the top on and draw a line to the side, half an inch from where I want the back to attach the side. Then I would use the radius sanding disk to see where the high spots are, and plane the excess off.
After that as usual.
Maybe a simple minded solution, but hey,you know me.
Re: Manzer wedge
What I've done is this - see pic.
What???? You've never braced a piece of pegboard with pieces of poplar that came off a tree that almost crushed your house? Sure you haven't....sure... :-)
- DSC01569.JPG (139.26 KiB) Viewed 750 times
