OK I'm pumped!
Re: OK I'm pumped!
Got the door openings painted and the electrical work done, had to tear out a bit of sheetrock to run the wire. So here are a few before shots so there will be some after comparisons.
- Door openings
- 7 Shop.jpg (359.07 KiB) Viewed 919 times
- Electrical Panel
- 8 Shop.jpg (202.93 KiB) Viewed 919 times
- Wall receptacle
- 9 Shop.jpg (259.52 KiB) Viewed 919 times
- Ceiling Receptacle
- 10 Shop.jpg (211.11 KiB) Viewed 919 times
- Entry
- 11 Shop.jpg (232.78 KiB) Viewed 919 times
- 12 Shop.jpg (221.53 KiB) Viewed 919 times
- 13 Shop.jpg (201.7 KiB) Viewed 919 times
- 14 Shop.jpg (246.24 KiB) Viewed 919 times
- 15 Shop.jpg (234.78 KiB) Viewed 919 times
Re: OK I'm pumped!
Tim that is totally awesome. I guess you could say a dream one true. Would be for me anywAy. Good for you. You go Boy!!
Re: OK I'm pumped!
Coming along nicely Tim, you are going to have a great shop.
Re: OK I'm pumped!
So the electrical inspectors came yesterday and told me the new code required TWO visible grounds and as the one on the shop was buried into the foundation I had to drive two more. For any that have not done this the rods are 8 feet long and must be driven flush to the ground. WHEW!
Well, the inspector came back today and everything passed, so I insulated the wall and sheet rocked it in. I'm getting to old for this s**t!!!!
- IMG_4812 (640x480).jpg (253.78 KiB) Viewed 911 times
- IMG_4814 (640x480).jpg (224.84 KiB) Viewed 911 times
Re: OK I'm pumped!
Ahh! Yes inspectors. Can be your friend or your worst enemy. Most are pretty cool if you just do what they want. Kind of like your wife. Lol
Re: OK I'm pumped!
Got the sheet rock up, 7 out of nine shop lights in and the frame for my spray booth. I'l be using positive flow in the booth to vent the space out.
- Shop lights
- 18 Shop.jpg (221.14 KiB) Viewed 900 times
- Spray booth framing
- 19 Shop.jpg (225.11 KiB) Viewed 900 times
Re: OK I'm pumped!
By positive do you mean that you will have a fan blowing air into the booth? Are you going to filter the air coming into your spray booth?
