Daniel P
Post by Daniel P » Fri Aug 16, 2013 10:31 am
Ken, as many of you know, has some great ideas on how to work with more precision, so as I work through the KMG Success Kit manual, I'm following his lead closely.
In preparation for doing the top bracing I built the jig mentioned here:
http://kennethmichaelguitars.com/Xbrace ... guide.html
It is noted that this is a left handed version, so I reversed all of the pieces to make a right handed jig.
1/4" Teak plywood was on hand, and worked nicely - I opted for 10-32 brass screw with a knurled brass thumbscrew - why not.
My razor saws are not deep enough to allow me to cut the full joint depth while using the jig - I am able to set an accurate angle, and cut to about 1/3 the final depth. In reality its better to finish the cut outside of the jig to enure absolute focus on the cut depth.
Daniel P
Post by Daniel P » Fri Aug 16, 2013 10:35 am
Carefully marking the X brace intersection
Daniel P
Post by Daniel P » Fri Aug 16, 2013 10:49 am
Someone told me it takes sharpening your scraper about 20 times before you really start to get the feel for it. Needless to say I have a few more to go.
This photo shows my lousy first attempt at sharpening the scraper, and my starting bridge plate thickness of between .104"-.108"
I was getting some descent rosewood curls off of my bridge plate after another pass at sharpening. Aiming for a final thickness of about .090" - ended up with slight variations between .88"-.092" - tonight I may try to bring down those final high spots just a hair.
Daniel P
Post by Daniel P » Fri Aug 16, 2013 10:51 am
Just admiring an evening's work.
I'm pretty pleased with the x brace joint - the angles seem to be right on, and the fit is clean and tight.
Daniel P
Post by Daniel P » Fri Aug 16, 2013 1:49 pm
Are the photos showing up for everyone?
Post by ken cierp » Fri Aug 16, 2013 2:09 pm
Photos look fine except some are just way too large -- requiring scrolling
Daniel P
Post by Daniel P » Fri Aug 16, 2013 2:13 pm
I'll work on scaling them down a little in future posts.
