D-28 Style Brazilian and Adirondack
Re: D-28 Style Brazilian and Adirondack
Post by Tim Benware » Wed Jun 12, 2013 4:56 pm
Blocks are in and I'm working on the braces.
13 X Brace Glue Up.jpg (415.9 KiB) Viewed 531 times
14 Neck Block Glue Up.jpg (406.97 KiB) Viewed 531 times
15 Tail Block Glue Up.jpg (412.52 KiB) Viewed 531 times
Bob Moore
Post by Bob Moore » Sun Jun 16, 2013 9:09 pm
Tim, how do you find that Safe-T-Planer to set up? How much tolerance can you stand with it if it's not drop dead on center? Is it forgiving in any way, or do you need to be special careful with it?
It looks like a very handy thing to have if one doesn't have a thickness sander.
Oh, yeh, this guitar is gonna be a good one. Looking good already.
Bob
Post by Dave Bagwill » Sun Jun 16, 2013 9:42 pm
BRW and Adirondack. Oh man.....like the holy grail. I look forward to following this one.
One question - is the grain on the tailblock vertical? Doesn't it make it more difficult to trim the block if need be?
Post by Tim Benware » Sun Jun 16, 2013 11:22 pm
Yes.
Post by Dave Bagwill » Mon Jun 17, 2013 10:13 am
Ah. It has always seemed to me that the vertical grain on the endblock makes sense as a preventer of possible splits on the sides. I guess the little bit of extra effort to trim the endgrain just is not a big deal.
Post by Tim Benware » Mon Jun 17, 2013 11:47 am
naccoachbob wrote:Tim, how do you find that Safe-T-Planer to set up? How much tolerance can you stand with it if it's not drop dead on center? Is it forgiving in any way, or do you need to be special careful with it?
Bob
I have a drill press table I use with it that needed the circular indent sanded out to allow the planer to cut to the edge. I use precision space blocks to measure the thickness I want and give my self about .01 extra thickness on the last cut so I can sand flat (I have a thickness sander). I use it to take off the bulk but it leaves circular lines that are slightly uneven and need to be sanded out.
Post by Tim Benware » Mon Jun 17, 2013 4:30 pm
Top braces on and kerfing in.
16 Braces On.jpg (397.56 KiB) Viewed 494 times
17 Kerfing Glue Up.jpg (456.9 KiB) Viewed 494 times
18 Kerfing In.jpg (467.1 KiB) Viewed 494 times
