Post by ken cierp » Tue Jul 09, 2013 12:29 pm
You'll be adding more coats of seal any how. Be aware and I think you are, that final finishing does not hide flaws it actually amplifies them.
mike-p
Post by mike-p » Tue Jul 09, 2013 12:38 pm
thanks Ken, am getting the idea, just watching videos on sharpening scrapers. . .
mike-p
Post by mike-p » Tue Jul 09, 2013 1:27 pm
is the headstock veneer a necessary part of the contruction, any tips on shaping the rough headstock? I could copy my SJ but i'd rather have straight sides like this
Post by ken cierp » Tue Jul 09, 2013 1:57 pm
I think some Gibson and others just have a thick coat of black lacquer. Tips -- sky is the limit, just look around out there. Make sure the finger-board and nut blend well.
mike-p
Post by mike-p » Tue Jul 09, 2013 2:05 pm
so instead of the nut sitting in a slot made by cutting away the veneer I will just cut a slot in the mahogany neck it's self? I'd like to leave off the veneer in the gibson style but not if it's going to make seating the nut at the end of the FB more tricky?
I'm assuming I'm putting my FB dots in after trimming but before fretting and attaching to the neck?
Post by ken cierp » Tue Jul 09, 2013 2:17 pm
In either of your senerios you'd have a real mess since the neck and fingerboard are designed/made so that the nut sits on the finger-board plane not the peghead.
mike-p
Post by mike-p » Tue Jul 09, 2013 2:38 pm
so the sawing through the headstock veneer in the instructions is just trimming the excess of the veneer which has overlapped onto the FB plane, am i understanding that correctly?
