Construction Log for KMG J45-Style Dreadnought
Re: Construction Log for KMG J45-Style Dreadnought
Post by Dave Bagwill » Fri Apr 12, 2013 9:06 pm
Nice work as usual, Dave!
Does that fiber tape wreak havoc on the grain when you remove it?
Post by dave d » Fri Apr 12, 2013 9:16 pm
Not at all. I didn't notice any difference (from painters tape) in the potential to pull up wood fibers when removing it. However, it seemed to be a bit stronger in pulling the binding tight against the channel.
Post by Dave Bagwill » Fri Apr 12, 2013 9:35 pm
Who carries the stuff?
Post by dave d » Fri Apr 12, 2013 9:45 pm
I found it at Staples in the box-packing section. Called Fiberglass filament tape.
Post by TonyinNYC » Fri Apr 12, 2013 11:34 pm
Looking gooooood!
Post by dave d » Sat Apr 13, 2013 8:38 pm
After the channels are cut and the mortise for the neck is opened, I check the neck angle and yaw. I did a little 'flossing' here to tweak the neck angle and then the yaw (left to right angle).
On this guitar (my 3rd) I think I'm almost getting the hang of having a nicely fitted neck-to-body.
Hopefully your neck lines up all the way down the seam where the top pieces are joined. This looks better in person than it does in the photo!
Now to glue on the bindings.  First I seal the channel with lacquer.
Tape the binding/purfling on tightly all the way around.
I'm using CA glue. A drop of glue is placed between the taped sections.  (Avoid getting glue on the tape). If there's a small gap and I have to hold the binding to close it, I use the CA accelerator on that spot.
After the binding is tacked down, I remove the tape and then flood the lines of binding and purfling with CA. Note the special S-M gap-closing stick :)
Prior to scraping the glue off.
A nice sharp scraper cleans up the edges and the back.
That's about a minute's worth of scraping.
See that dent? (Who did that?)  Don't try to sand it out!  Get out the clothes iron. Put a drop of water on the dent, put a paper towel over the drop, and iron it for a second or two. You'll hear it steam.
where'd the dent go?
Post by Dave Bagwill » Sat Apr 13, 2013 9:00 pm
Good work David.
