Safest way to remove a bridge (titebond I'm pretty sure)
Re: Safest way to remove a bridge (titebond I'm pretty sure)
Don't be afraid - YOU CAN DO EET!
No fear Tim, just the utter, placid, settled animosity toward extra work (should a chip come off the top or whatever). Plus, first time or two who knows - I may get the bridge off with heat, call it a success, but because of inexperience loosen the glue on the xbraces, to show up only later in crash with a bridge abutment. Just sayin' - I may have to just go with what I know.
Plus I live my life by WWOD?
What Would Oprah do???
I have removed a bridge with heat and a cold scraper, some tape around the bridge set bit back a bit and the bridge came off no problem. Unfortunately I did not notice what the handle was doing. So I did have a bit of clean up where I scratched the top finish with the plastic handle of the scraper.
Yes, that can be an issue which is why now all my knifes have an offset handle that holds them up above the top surface.johnparchem wrote:I have removed a bridge with heat and a cold scraper, some tape around the bridge set bit back a bit and the bridge came off no problem. Unfortunately I did not notice what the handle was doing. So I did have a bit of clean up where I scratched the top finish with the plastic handle of the scraper.
I have found a heat lamp with the right insulation on finished areas works. The heating is very even over the total area of concern. Have used it for both bridges and fingerboards. When doing bridges one can route the main mass of the bridge off and thus the heat needs to be on for a much shorter time thus with the possibility of less intrusion into the center seam. I would suggest that the sharp blow method only be tried on bridges glued with HHG.
Tom
Tom
That use of the router is a good tip. Thanks.
I took this one off with no heat. I was lifting pretty good.
- 1 Gap While Strung.jpg (331.93 KiB) Viewed 1560 times
- 3 Bridge Off.jpg (405.5 KiB) Viewed 1560 times
- 4 Contouring Bottom.jpg (424.25 KiB) Viewed 1560 times
- 5 Checking Progress.jpg (381.11 KiB) Viewed 1560 times
- 6 Glue Up.jpg (400.38 KiB) Viewed 1560 times
