My new Wagner Safe-T-Planer Setup...
Robert Hosmer
Re: My new Wagner Safe-T-Planer Setup...
Router is probably way too fast. Instructions for the Woodtek have max RPM of 4500?
Mine has a max recommended RPM of 4500 I believe
J Phillips
Drat. Foiled again. Thanks
Jim Phillips
Will work for G-code.
Hopefully the images work this time.
Daniel P wrote:Have any of you used the currently available WOODTEK 24-760 DRILL PRESS PLANER?
http://woodworker.com/fullpres.asp?PART ... RGEVIEW=ON
As good as the original Wagner Safe T Planer?
Yes thats what I use. Works well but i already have a problem where one of the screw heads that attaches the cutters has rounded and i will have a lot of trouble getting that cutter out to sharpen it not. I would buy another if it can be done because i find them a good tool but you really have to concentrate and understand the advise given by robbioe o brien and others about using it.
Oh, and make the jig--its pointless otherwise as the chips and sawdust will just build up behind it and clog up
Hope this helps
Rusty
Rusty, what jig have you built for yours?
Robert Hosmer
Works best with a separated fence. The video by O' Brien is pretty straightforward and that method works well.
