Post by Kevin in California » Sun Jul 30, 2023 8:37 pm
Thanks Herman. Yours looks good. That's encouraging.
Worked just an hour today. I refined the top arching a bit and marked off the inside area that will be carved.
I had already laid out the neck on the maple blank so I cut it out and two pieces for "wings" on the headstock to make it wide enough for my design, which is one of the ones supplied on the Benedetto plans.
Tomorrow I think I'll work on jointing the back plate (by hand with a hand plane" and see if I can get them glued up
Post by Kevin in California » Tue Aug 01, 2023 11:26 pm
Made some more shavings hollowing out the top.
Today I jointed and glued the maple back plates.
Post by John Parchem » Wed Aug 02, 2023 10:28 am
Interesting work. Looks like a lot more craving than you violin plates.
Post by Kevin in California » Wed Aug 02, 2023 9:46 pm
Oh yeah like 3 times the surface area. Not looking forward to carving the maple back.
Today I made a template of an F hole on heavy paper stock. It's made so the edge of the paper aligns with the center line and the bridge placement. Mark one side and flip it over to do the other side.
Then I used a 24 tooth coping saw blade to rough out the holes after drilling starting holes.
I'll finish up using a carving knife and various homemade sanding sticks. Flat, curved and round.
These will be bound with plastic purfling same as will be around the guitar so the edges have to be flat and square.
Easier said than done!
Jim Ebert
Post by Jim Ebert » Thu Aug 03, 2023 11:25 am
Kevin, I've been off doing some adventuring and just got caught up on this. Far out man... love your detail in both your construction and posts. As always, thanks for doing this. It gets my juices flowing.
Jim Ebert
Post by Kevin in California » Thu Aug 03, 2023 11:14 pm
Hey Jim
Glad your enjoying it.
I'm trying to cover each step so hope it stays interesting.
Today I finished cutting out and cleaning up the F holes. They are ready for binding. I have laminated ABS strips for this I just need to decided what combo of black and white I want.
Then I cut out the back profile and began the carving. Got about a fourth of the wood removed. Tedious but also satisfying. Sure makes a pile of shavings.
Post by Kevin in California » Fri Aug 04, 2023 11:34 pm
After a bit more carving mostly around the perimeter I took the back to the drill press and using a Safety Planer took the edge down to just over a 1/4" in about 3/4".
Once I get the arching down close to shape I'll Safety plane it down to the final edge thickness of 3/16". From there I'll finalize all the arching. Tedious but relaxing at the same time.
