Stahl Style 6 Build
Re: Stahl Style 6 Build
Thanks John, can you compare it to any other woods as far as feel, weight and tap?
We purchase that material under the name "Santos Rosewood" -- I believe Taylor has offered some models made of it. Its slightly heavier and 20% less hard compared to East Indian Rosewood. Less porous as well. Our supply was more brownish, no purple shades and none was as dark as EIR.
The wood itself is a dream to work with. And it sounds very good. No porefilling needed.
About the reaction: I don't recall it clearly, 'cause it is 10 years since. But I remember waking up in the middel of the night with a wheezing repiration. Never had it before or after.
herman
herman
Finished up gluing the braces in the go bar deck ( I like the ability to easily clean up the glue). Carved the braces and sanded both top and back. Notched the rims and will be ready to close the box.
- IMG_6334.JPG (102.58 KiB) Viewed 955 times
- IMG_6336.JPG (154.5 KiB) Viewed 955 times
- IMG_6337.JPG (124.17 KiB) Viewed 955 times
JJ
Some progress and some obstacles overcome. Not routing the back binding rebates before routing the neck mortise is not a good idea. Thought long and hard about how to fix this one. I decided to inlay a MOP triangle to disguise it. I also did one at the tail for symmetry. Overall pleased with how it turned out. Installing the top binding and purfling was challenging to say the least. That done I used my orbital sander and accidentally sanded through the outer rosette. (It was not as deep in that area because I had to rout the channel after I had installed the x braces. Soooo. Now what. Well I made up an insert that would fit snugly in the sound hole and carefully re-routed the outer channel. Installed the new purfling strip. Whew. I gotta start thinking before doing a little more often. Moving on I finished the headstock and fingerboard inlays. I fretted the board with Jescar m/m and my new fret press. What a joy. Pressed in perfectly. Very nice wire.
- IMG_6412.JPG (125.32 KiB) Viewed 904 times
- IMG_6413.JPG (143.81 KiB) Viewed 904 times
- IMG_6414.JPG (157.66 KiB) Viewed 904 times
- IMG_6415.JPG (122.88 KiB) Viewed 904 times
- IMG_6416.JPG (105.96 KiB) Viewed 904 times
- IMG_6417.JPG (192.1 KiB) Viewed 904 times
- IMG_6418.JPG (135.45 KiB) Viewed 904 times
- IMG_6419.JPG (114.63 KiB) Viewed 904 times
- IMG_6421.JPG (128.95 KiB) Viewed 904 times
- Instead of cutting or nipping the fret ends I've found that my little belt sander works great.
- IMG_6422.JPG (110.53 KiB) Viewed 904 times
JJ
Some great 'saves' there John - thanks for the pix. I'm betting this turns out really nice.
Hi John, thank you for sharing the photos. Very nice work.
You got a very interesting tool for pressing the fret into the FB.
Did you make it by yourself?
Would you mind sharing some info about that tool?
Thanks a lot.
Thanks a lot.
