Rosette with a lot of inlaywork, now ready
Making and Installing
Re: Rosette with a lot of inlaywork, little blog
Post by Herman » Thu Jan 01, 2015 10:12 am
After all inlay work is done, all the gaps were filled with epoxy. stained with black dye.
Scraping the epoxy off and a carefull pass under the thickness sander. It's only 1,5 mm thick!!!
Taking the outer perimeter off with the dremel.
Glueing the purfling b/w/b on after a touch bending. Had to borrow the needles from the misses.
You could mention: why b/w/b? Why not just b/w to the ebony.
Well before I had some tiny gaps between the rosette and the purfling. And these are easier to cover between black and black.
Gaps between black and white show more easily.
So that is why.
Post by John Link » Thu Jan 01, 2015 11:03 am
Herman, you have a very beautiful design in the first place, though a tough one to execute. But thanks to your rather profound level of craftsmanship, the execution simply reinforces the strength of the thinking that went into the design.
Re: Rosette with a lot of inlaywork, now ready
Post by Herman » Tue Mar 17, 2015 3:27 pm
After cutting the inside off, the inner purfling is prebent and glued. Trying to keep all in a perfect circle.
Routing the rosette in the usual way.
Despite all effort the rosette was not perfectly round so the slot had to be made a touch wider. After glueing it in the tiny gaps were filled with pumice, glue and black dye. I have to say it looks flawless now.
Here's the soundhole completed:
Mission completed.
Post by Kevin in California » Tue Mar 17, 2015 3:37 pm
Herman that is just SWEET! Nice job!
Post by John Link » Tue Mar 17, 2015 4:09 pm
Positively gorgeous Herman, way to go.
Post by Dave Bagwill » Tue Mar 17, 2015 4:11 pm
Well done, Dutchman!! :-)
Post by John Parchem » Wed Mar 18, 2015 12:20 am
really nice! That is a lost of inlay work
