Planing with a router
Re: Planing with a router
Just noticed the router bits - - - seeing as how I have a router I've never used that takes 1/2" shank bits, I think I'd like to start working on this - - - is the largest diameter of the three router bits the best choice? The price seems to hardly matter. Thanks!
Hot glue works great for tacking down blanks. Its best to surface the table with your router set-up to make sure the plane matches the gantry and rails. Then glue down the blanks. Here's a bit Dave Bagwill found that should work fine
http://www.grizzly.com/products/C1257
Is the 3/4" about right, or the 1" or larger?
3/4" will work fine
router bit diameter - - - The router I intend to use has a calculated power output of 1.5 horsepower (115 volts x 9.5 amps)/745. So...suggestions as to how large a router bit can I happily swing with this router. Am I wondering about a meaningless characteristic? Will a 1-inch or 1.5-inch router bit do a more satisfactory job than a 3/4-inch bit, provided that my router has enough ability to turn a larger bit?
Thanks very much.
Thanks very much.
