The price was right!Kevin in California wrote: ↑Thu Feb 17, 2022 10:13 am Thanks John
Remember that Simpson mortise and tenon jig?
It still works although not super accurate.
Yesterday I began to figure out my screw down fretboard extension setup. Made a block that will hold the T nuts and be glued to the fretboard bottom and made a pattern and routed the cavity in the top. Took lots of time fitting and fiddling with this but it looks like it will work. Today I'll install the nuts, drill holes, etc. Not ready to glue the block to the fretboard yet. I want to install most of the frets first other than where the locating pins go......I think.
John. Why do my pics turn 90 degrees when I upload them?
It used to be digital photos basically were oriented however the camera was. Upside down camera upside down pictures. Then the cameras got orientation sensors, they knew they were upside down. The jpeg standard added a field in the metadata giving the orientation, the payload, the picture itself, stayed the same. Now we are in a situation where half the software uses the orientation when displaying the picture the other half doesn't. WIndows itself does so it looks right in the file explorer. Unfortunately if you rotate a picture in the file explorer it just changes the metadata not the picture. This software down not look at the metadata.
I use photoshop to reduce all of my images when they write the reduced image they turn the picture for real.
