would someone please give me some idea of the best way to go about this ? I assume...(There's that word again) that the channels for the Rosette should be done first? Now I am worried...I really don't want to screw this top up!
Thanks,
Ray
Cutting the sound hole
Re: Cutting the sound hole
Hey Ray,
You need a device that follows a circle around a centerhole.
To make all more visable for yourself, you can use a drawing compass before cutting. So you can see the layout of your rosette and soundhole.
I use the Stewmac jig, a dremeltool and a downcutbit. First you rout the rosette in what order you like. The soundhole is cut out last ('cause you loose the centerpoint with that). The latter I do that halfway from one side and the other half from the other side. That way you don't cut into the workboard.
Here's the idea:
Here's the idea:
Ok...thanks Herman...I know it seems simple if you've done it before.. but? Now with your help and the pic I got it...I have all the tools necessary, just didn't really understand how to use them in this situation, thanks Sooo much again for your help!!!
