maybe I should just invest in a digital one :)Tim Benware wrote:Well it's hard to see the mark you are measuring by but I believe John P is right, it is probably closer to 89*. Seems like it depends which surface you put that on as to which row to read. I am pretty sure if you contact the maker he'll know what degree he cut it to and it should be real close to that if not dead on.
Neck angle second chance.....
Re: Neck angle second chance.....
For your situation (that brand of protractor, placed on the neck in that way), yes, it's the bottom row.MarkAndrew1 wrote:So, just for the sake of my clarity. The bottom row of numbers
is the one I should have been reading to get the neck angle?
I'm terrible at this stuff but trying to learn.....
As a visual double-check, your second photo does look like it is less than 90*, which as the other fellows have said, is correct. It should be close to 89* and that's what it looks like to me. If you held a small machinists square (90*) on it, you would see a gap there, so therefore the angle is less than 90.
Yeah, you're right Dave. The black line in the protractor is between 90 and 89deg's. So,dave d wrote:For your situation (that brand of protractor, placed on the neck in that way), yes, it's the bottom row.MarkAndrew1 wrote:So, just for the sake of my clarity. The bottom row of numbers
should I just call it 89deg's? That would give me 89+91=180. The complimenting angle
at the body should be 91deg to form the straight line I'm looking for.
You need to flip the protractor the other way so the long part lays along the "cheek" of the heel --- not next to the tenon. that is the angle which is important, where the heel contacts the body -- I bet its 88.5 +/-
Ahhh, so not along the fingerboard side like I have it in the picture. Okay, I'llken cierp wrote:You need to flip the protractor the other way so the long part lays along the "cheek" of the heel --- not next to the tenon. that is the angle which is important, where the heel contacts the body -- I bet its 88.5 +/-
do that tonight. It should be 88.5 cause it's straight from Martin. So, 88.5+91.5= 180degs.
That should do it....
After I confirm that then I will make sure the mortise area is completely flat (just a light
sanding) and then remove the mortise cap to put the neck on and see where I'm at.
Okay, so i took the protractor and flipped it around so that
the long side is on the cheek of the neck. In the close up picture
you can see that it's reading between 89 and 90deg. Am I reading
it right this time? I think i am.
I'm assuming that I'm supposed to be using the top row of
numbers now since I flipped the protractor over. Is that correct?
- photo(95).JPG (49.76 KiB) Viewed 728 times
- photo(94).jpg (167.23 KiB) Viewed 728 times
