It is currently Thu Jan 18, 2018 11:46 am
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: Binding purfling gaps
PostPosted: Fri Sep 26, 2014 10:29 am
Offline
What is a good method and materials to sew this crack up? I read somewhere on forum about dust and ca glue
Top
 Profile
 Post subject: Re: Gap filling
PostPosted: Fri Sep 26, 2014 10:39 am
Offline
Is the gap between the binding and the purfling? Is the binding loose?
_________________
Top
 Profile
PostPosted: Fri Sep 26, 2014 11:52 am
Offline
Gap is between the back plate and purfling. The binding is not loose.
Top
 Profile
PostPosted: Fri Sep 26, 2014 12:08 pm
Offline
If the channel is right you can heaten the place and try to push the binding dowwn.
If the channel is routed too deep, you need filling. You can choose for making it black as the inner purfing, but here I would choose filling with a brown/rosewood maching color. Either way it with show somehow.
This is exactly why I will buy me a better binding-router-guide soon.
FWIW
Top
 Profile
PostPosted: Fri Sep 26, 2014 12:29 pm
Offline
You should be able to apply some heat and soften the glue -- use filament packaging tape to pull the purf and binding tight to the back plate.
_________________
http://www.kennethmichaelguitars.com/kitinfopackage.html
Top
 Profile
PostPosted: Fri Sep 26, 2014 5:34 pm
Offline
Great ideas thanx fellas
Top
 Profile
PostPosted: Fri Sep 26, 2014 10:21 pm
Offline
I use a heat gun to heat the binding; careful not to scorch the wood. I first put some glue in the gap and heat the binding with the heat gun, it does not take long. I watch the glue in the gap that I put in when I see it change (can not describe it but it takes on a different look.) I use tape to pull the binding tight. You will get a bit of squeeze out from the new glue you put in.
I got this procedure from Rick Davis, a luthier I took a class from. It should close what I see in the photo. If the binding are bridging a curve, or bowed out where the wood would need to either stretch or shrink to close the gap this will not work. But most of the time it does close the gaps.
_________________
http://www.harvestmoonguitars.com
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
